Hi all
Have just set up an ouverture linked via 1614 converter(yes the box will function in this configuration!) to the MX7000 driving 2 x BL 6000's - the system setup using the configuration guide, appears to work ok but I need to check against a pair of Pentavoxes thro' an ml/mcl or passive box.
I do however have a question regarding the use of non BnO peripherals as above, which is how should the units be connected to the TV - have tried various configs but cannot get the dvd to play with a clear non-rolling screen.
The sat box(panasonic) is plugged into AV1 the VCR(samsung-secam - used to receive terrestrial French output) is plugged into AV2 and daisy chained into and thro' this is the dvd.
Also used is a A/V transmitter to another setis is plugged into the sat box - this configuration worked perfectly with an MX5500(BL1000 Sat controlled sat viewing V/tape controlled vcr and dvd viewing.
Cannot set up the 7000 similarly as the tv has a beosat module fitted and i do not think removal of this unit will change the situation!
A smaller issue is how to call up V/Tape2(ie AV2 scart) AV! is called by pressing V/Tape on BL1000n - have trie shift / V/Tape to no avail -Help!!
Salut from a stormy Finistere
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
