Latest post 01-26-2009 9:02 PM by Piaf. 7 replies.
Page 1 of 1 (8 items)
  • 01-17-2009 8:46 PM
    • Piaf
    • Top 150 Contributor
    • Joined on 07-08-2007
    • Victoria, British Columbia
    • Posts 409
    Beomaster 2400 smells like electrical fire mixed with oil
    I posted a “general” question on Beomasters in regard to their service needs over time. After posting I noticed a distinct odor coming from my Beomaster 2400, smells like an electrical fire mixed with hot oil. Pungent and nasty.
    The Beomaster 2400 plays well and all functions work correctly, but I wonder if this isn’t a clear sign of transistor or diode failure in progress?
    I wanted to know if the smell would get worse under load and/or there would be distortion however the S45 speakers I have connected to this Beomaster can not handle the power of this unit due to issues with one of the woofers.
    Any thoughts on this one?
    Jeff
  • 01-18-2009 5:04 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 2400 smells like electrical fire mixed with oil
    Jeff,
    Sounds like too high idle current(s).
    Replace the trimmers and adjust to factory specs.
    Could also be the board mounted rectifier toasting. It's fairly low dimensioned
    from the factory so I like to replace it with a somewhat more powerful type.
    We can never rule out caps either.
    - Or any combination of the above.
  • 01-18-2009 12:42 PM In reply to
    • Piaf
    • Posts 409
    Martin,
    My thought was to open the 2400 up and see if my nose can lead me to the problem. With such a strong odor I imagine the offending component will make itself known. Just my thought.
    Jeff
  • 01-18-2009 5:36 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Piaf:
    Martin,
    Jeff
    Not a bad idea, I have done the same myself and it has worked.
    CraigSmile
  • 01-18-2009 10:37 PM In reply to
    • Piaf
    • Posts 409
    Hi Craig,
    Well unfortunately my Beomaster 2400 “passed” the smell test, that is to say, under load, the smell diminished.
    I had fully expected to find a transistor or a capacitor leaking, or possibly smoking, but that was not the case. Everything looked as it should.
    I noticed that several “components” were warm to the touch, for lack of a more technical term, but nothing seemed hot.
    Perhaps I might have found something had I wired the 2400 to my McIntosh ML-2’s and really gave them a go, but the S-45’s simply are not up to a high power performance. The 2400 did a superb job powering those huge inefficient speakers, but there was a conflict with my McIntosh 2255 amp and I now have the systems completely separate.
    At least I was successful in adjusting the tonearm drop of my Beogram 4000 that had developed a “spastic” drop following its international voyage for repair. The arm just shook from side to side while dropping like a guillotine. Now it comes down straight and reasonable slowly.
    Jeff
  • 01-19-2009 2:17 AM In reply to
    • Dillen
    • Posts 5,008
    Jeff,
    I would check the idle current trimmers. They don't go out of adjustment, they oxidize and can even fall apart physically. First signs of problems is unstability and intermittent faults, then bad smells, smoke and deformation of the plastic grill above the cooling fins. If a trimmers slider oxidize or lose its tension and thereby connection, the resistance of the trimmer goes high and that brings the idle current way up. This will toast the output stage emitter resistors and transistors in a matter of minutes and seconds.
    The trimmers are cheap components, easily replaced and adjusted if you have a DC millivoltmeter. Do one channel at a time, starting with the (most) defective.
  • 01-19-2009 1:02 PM In reply to
    • Piaf
    • Posts 409
    Hi Martin,
    I ignored your previous suggestion about the trimmers not wanting to acknowledge that I have no idea what trimmers are.
    So since I can no longer hide my ignorance, what are idle current trimmers? Where are they located? What do they look like? And what do I test for?
    Thus far there are no intermittent faults as the 2400 does everything it is supposed to do: play music from all sources. The plastic panel above the cooling fins is fine, and the smell, which has diminished considerably, is coming from the center of the receiver, not from the back where the cooling fins are.
    I had really hoped to find an over-heated component, or one leaking, but this is not the case…. yet.
    I had played the 2400 for an extended period, well over an hour trying to find the source of the smell, but gave up when the odor began to go away.
    So does it still sound like the trimmers and if so, directions please….
    Thanks, as always.
    Jeff
  • 01-26-2009 9:02 PM In reply to
    • Piaf
    • Posts 409
    Just a quick update.
    The Beomaster 2400 continued to play without the slightest problem and the odor slowly diminished.
    As such Martin feels that it was likely dust collecting in a hot area and giving off the nasty smell.
    Jeff
