Hi Martin,
I ignored your previous suggestion about the trimmers not wanting to acknowledge that I have no idea what trimmers are.
So since I can no longer hide my ignorance, what are idle current trimmers? Where are they located? What do they look like? And what do I test for?
Thus far there are no intermittent faults as the 2400 does everything it is supposed to do: play music from all sources. The plastic panel above the cooling fins is fine, and the smell, which has diminished considerably, is coming from the center of the receiver, not from the back where the cooling fins are.
I had really hoped to find an over-heated component, or one leaking, but this is not the case…. yet.
I had played the 2400 for an extended period, well over an hour trying to find the source of the smell, but gave up when the odor began to go away.
So does it still sound like the trimmers and if so, directions please….
Thanks, as always.
Jeff
