Latest post 01-30-2009 6:48 PM by olavito. 3 replies.
Page 1 of 1 (4 items)
  • 01-07-2009 8:07 PM
    Connecting MACbook to MX5000
    I have an old MX5000 which I am very happy with.  It is an amazing TV and I'm not interested in upgrading to something flashier or more expensive.
    I have a MACbook and I would love to connect it to the TV, but perhaps the TV is too old - I think I got it in 1993.
    I'm not the most tech-savvy person in the world, so if replies could be dumbed down it would be great.
    Thanks,
    olavito
    Filed under:
  • 01-07-2009 8:43 PM In reply to
    Re: Connecting MACbook to MX5000
    Olavito,
    don’t worry, that is quite simple. Unfortunately, you need a lot of cables and adapters.
    1. Apple mini-DVI to video adapter
    2. Audio cable, miniplug on one side, chinch plugs on the other
    3. Euro-AV to chinch adapter
    Connect 1. and 2. with your mac and on the other side with the Euro-AV adapter. Once you’ve pluged in the Euro-AV adapter into a MX5000’s port everything should work the way you want. It’s a great way to use your mac for dvd playback or photos.
    Kind regards,
    Frank
  • 01-30-2009 6:32 PM In reply to
    I have never even heard of these cables!
    I'll investigate and get back to you,
    Thanks,
    Olavito
  • 01-30-2009 6:48 PM In reply to
    does the new analog to digital stuff make a difference if i play movies on the computer and hook it up to the television?
