Olavito,
don’t worry, that is quite simple. Unfortunately, you need a lot of cables and adapters.
1. Apple mini-DVI to video adapter
2. Audio cable, miniplug on one side, chinch plugs on the other
3. Euro-AV to chinch adapter
Connect 1. and 2. with your mac and on the other side with the Euro-AV adapter. Once you’ve pluged in the Euro-AV adapter into a MX5000’s port everything should work the way you want. It’s a great way to use your mac for dvd playback or photos.
Kind regards,
Frank
