Hi, I have a problem with my linksystem and hope that someone can help me. Posted a thread some months ago regarding almost the same problem and then got the advice to buy the RF-amplifier which I now have installed.
My system contains of a BV 7-40 MKIII, a BV 7-32 and a BV 6-26. The BV 7-40 is the master in the system and I have set V. OPT 2 on the BV 7-40. The BV 7-32 is set to V. OPT 6 and from the 7-32 I can control both my Dreambox (SAT) and for example a DVD that is placed in the 7-40.
Today I connected the 6-26 to the system and I get the picture if i press for example DVD, but I am NOT able to control anything, not SAT or DVD. I think I have tried all options; V. OPT in 5 and 6, L. OPT in 6, but nothing seems to work.
Does anyone have any ideas what I can try ? I am almost certain that the link connection is OK since I controlled the 7-32 through my old MX4002 earlier. Is there any way to make sure that the Master Link is OK at the 6-26 ?
Best regards
Hans
