Latest post 01-08-2009 11:19 AM by halid. 2 replies.
Page 1 of 1 (3 items)
  • 01-05-2009 10:58 AM
    Link problems
     Hi, I have a problem with my linksystem and hope that someone can help me. Posted a thread some months ago regarding almost the same problem and then got the advice to buy the RF-amplifier which I now have installed.
    My system contains of a BV 7-40 MKIII, a BV 7-32 and a BV 6-26. The BV 7-40 is the master in the system and I have set V. OPT 2 on the BV 7-40. The BV 7-32 is set to V. OPT 6 and from the 7-32 I can control both my Dreambox (SAT) and for example a DVD that is placed in the 7-40.
    Today I connected the 6-26 to the system and I get the picture if i press for example DVD, but I am NOT able to control anything, not SAT or DVD. I think I have tried all options; V. OPT in 5 and 6, L. OPT in 6, but nothing seems to work.
    Does anyone have any ideas what I can try ? I am almost certain that the link connection is OK since I controlled the 7-32 through my old MX4002 earlier. Is there any way to make sure that the Master Link is OK at the 6-26 ?
    Best regards
    Hans
  • 01-05-2009 11:30 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Link problems
    Try to disconnect the master from the mains for a minute - everything should be in standby - may be this helps.
    Option settings are correct, I think.
    Stefan
  • 01-08-2009 11:19 AM In reply to
    Re: Link problems
    Thanks for your suggestion Stefan, unfortunately it didn't work. More suggestions anyone ?
    Regards
    Hans
