Thank you so much!!!
I was searching the net for days
|BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
I have installed the 2.2 software successfully and I can see the firmware folder. I have not created a 2.2 configuration so far as I was waiting for the firmware update to happen. What do I need to do to make the FW update?
Thanks,Frank
kurfuer:you have to send a new config to the Beo5; during the download process the FW update will be initialized
Ah ok, got it!
Thank you so much Peter.
I really appreciate it.
Peter Pan:Beo5 Configuration tool to the latest version is 2.20 include the latest Firmware Version is 1.40a. Beo5 Konfiguration værktøj til den nyeste version 2.20 inkludere nyeste firmware version er 1.40a.Download from Bang & Olufsen club Danmark. .Link: http://www.hifi4all.dk/forum/forum_posts.asp?TID=46053&PN=1&TPN=19________Switch-over link : http://forum.beoworld.org/forums/7/1624/ShowThread.aspx .Best regard/ Peter Pan.
