Latest post 01-19-2009 3:05 PM by Sebastien. 7 replies.
Page 1 of 1 (8 items)
  • 01-01-2009 1:30 PM
    Beo5 configuration tool
    Any link to download the latest Beo5 Configuration tool?
  • 01-12-2009 1:01 PM In reply to
    Re: Beo5 configuration tool
    Beo5 Configuration tool to the latest version is 2.20 include the latest Firmware Version is 1.40a
    Beo5 Konfiguration værktøj til den nyeste version 2.20 inkludere nyeste firmware version er 1.40a
    Download from Bang & Olufsen club Danmark.
    Link:  http://www.hifi4all.dk/forum/forum_posts.asp?TID=46053&PN=1&TPN=19
    ________
    Switch-over link :  http://forum.beoworld.org/forums/7/1624/ShowThread.aspx
    Best regard/ Peter Pan.
  • 01-12-2009 1:15 PM In reply to
    • francis
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Münster, Germany
    • Posts 108
    Thank you so much!!!
    I was searching the net for days
    |BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
  • 01-19-2009 5:00 AM In reply to
    I have installed the 2.2 software successfully and I can see the firmware folder. I have not created a 2.2 configuration so far as I was waiting for the firmware update to happen. What do I need to do to make the FW update?
    Thanks,
    Frank
  • 01-19-2009 5:03 AM In reply to
    • kurfuer
    • Not Ranked
    • Joined on 04-22-2007
    • Dresden
    • Posts 35
    you have to send a new config to the Beo5; during the download process the FW update will be initialized
  • 01-19-2009 6:07 AM In reply to
    kurfuer:
    Ah ok, got it!
    Thanks,
    Frank
  • 01-19-2009 3:03 PM In reply to
    Thank you so much Peter.
    I really appreciate it.
  • 01-19-2009 3:05 PM In reply to
    Peter Pan:
    ________
