Hi all,
I have a minor but annoying problem. In the same room I have a 32" VHS Avant & a system 5500. They are not linked at present - that may happen some time in the future if I decide to buy a converter.
The problem I have is when I press the TV button on my remote the BM5500 also fires up on AUX. I don't know if this is an option problem with the 5500 or a minor fault with it.
Chris.
EDIT - I've sorted it. The BM5500 seems to have been in the wrong option. I've reset it to option 1 (which I thought I had done but I must have pressed the button sequence incorrectly
