Latest post 12-30-2008 8:39 AM by Medogsfat. 2 replies.
Page 1 of 1 (3 items)
  • 12-30-2008 8:03 AM
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Avant & BM5500
    Hi all,
           I have a minor but annoying problem. In the same room I have a 32" VHS Avant & a system 5500. They are not linked at present - that may happen some time in the future if I decide to buy a converter.
    The problem I have is when I press the TV button on my remote the BM5500 also fires up on AUX. I don't know if this is an option problem with the 5500 or a minor fault with it.
    Chris.
    EDIT - I've sorted it. The BM5500 seems to have been in the wrong option. I've reset it to option 1 (which I thought I had done but I must have pressed the button sequence incorrectlyEmbarrassed)
  • 12-30-2008 8:13 AM In reply to
    Re: Avant & BM5500
    Must be an option problem - my 6500 doesn't respond to any of the video commands, but turns on on AUX if I select AV-TV (or AV-videoanything).
    I'd try reprogramming the Beomaster to Option 1 first.
    -mika
  • 12-30-2008 8:39 AM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Avant & BM5500
    Thanks Mika - yes I worked it out just after I had first posted. I thought I had set the BM to option 1 but I must have pressed the button sequence incorrectly - how embarrassing.
    Chris.
