Latest post 12-16-2008 2:14 PM by TWG. 4 replies.
Page 1 of 1 (5 items)
  • 12-10-2008 5:15 PM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Configtool 1.30: Serialisation ... and then nothing. Help please
    today I changed some things in my beo 5 configuration. Saved the config, hit "download" and serialisation started, warned about some errors in the configuration (I always hat those error warnings since I started configuring the beo 5 for the first time). When the windows says "serialisation finished" I hit "close" and the software tells me:
    "The serialisation contains some errors, do you want to download?"
    I hit "yes" and that's it: Nothing happens after I hit yes. The infodialog closes but that's it. Nothing happens.
    I restarted the Beo 5, the computer, disabled systemtasks like "iTunes Helper" or "Palm Hotsync" but nothing :-(
    Any help?
  • 12-10-2008 5:28 PM In reply to
    Re: Configtool 1.30: Serialisation ... and then nothing. Help please
    I had this problem a while ago, and I plugged it into a different USB port and then it worked... try to avoid going through a HUB.
  • 12-11-2008 8:55 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
     thank  you for the tip but it didn't work: I plugged it into another usb-port, tried another cable, reboot the Beo5 and the computer but nothing happens :-(
  • 12-11-2008 10:26 AM In reply to
    • Quim43
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Try to do this:
    Keith Saunders:
    wtlc2zpx:
    I am trying to update my Beo5 with a new config, and strangely, it refuses to update.
    The software sees the remote, I am able to click on Download, It serialises and does not seem to display any error message, but the remote remains in the configuration?!?
    p.
    After your initial posting and subsequent updates I started to do a few tests and I can confirm that I can reproduce your symptoms and it appears to be linked to getting USB errors. Disconnecting the Beo5 and re-connecting it and doing an immediate download again causes normal operation to return each time. I have not yet been able to establish the exact steps which gets the program into this situation, but it is certainly in the routine which sets up the USB ready for the transfer prior to the actual download.
    Quim
  • 12-16-2008 2:14 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    it didn't help Angry
    any tipps?
