today I changed some things in my beo 5 configuration. Saved the config, hit "download" and serialisation started, warned about some errors in the configuration (I always hat those error warnings since I started configuring the beo 5 for the first time). When the windows says "serialisation finished" I hit "close" and the software tells me:
"The serialisation contains some errors, do you want to download?"
I hit "yes" and that's it: Nothing happens after I hit yes. The infodialog closes but that's it. Nothing happens.
I restarted the Beo 5, the computer, disabled systemtasks like "iTunes Helper" or "Palm Hotsync" but nothing :-(
Any help?
