To start or stop TIMER OFF you press the right side of the front (POWER) and while pressing it press the left side (STEP) quickly, then the TIMER OFF should stop. This function is for cutting the sound in mainroom while you have a TIMER set for a LINK-room.
Hope that helps
Jesper
Sweden
