Latest post 12-07-2008 7:21 AM by Pault1965. 2 replies.
Page 1 of 1 (3 items)
  • 12-07-2008 5:42 AM
    • Pault1965
    • Not Ranked
    • Joined on 04-22-2008
    • Rogiet, South Wales
    • Posts 36
    Beomaster 5500
    On my Beomaster 5500 the words 'Timer Off' are constantly lit. Is it possible to 'turn them off' please?Unsure
    Cheers
    Paul
    Filed under:
  • 12-07-2008 6:12 AM In reply to
    Re: Beomaster 5500
    To start or stop TIMER OFF you press the right side of the front (POWER) and while pressing it press the left side (STEP) quickly, then the TIMER OFF should stop. This function is for cutting the sound in mainroom while you have a TIMER set for a LINK-room.
    Hope that helps
    Jesper
    Sweden
  • 12-07-2008 7:21 AM In reply to
    • Pault1965
    • Not Ranked
    • Posts 36
    Re: Beomaster 5500
    Cheers Jesper, just goes to show that you really do learn something new every day!
    Paul
