Latest post 12-11-2008 12:19 PM by Dillen. 15 replies.
Page 1 of 1 (16 items)
  • 12-01-2008 2:17 PM
    Beolab Penta hum
    Hi!
    One of my penta II:s just started to hum. Only when turned on and always at the same level. Raising volume doesn't affect the humming. When muted or turned off (stand by) it goes away
    Any suggestions
    regards
  • 12-01-2008 2:28 PM In reply to
    Re: Beolab Penta hum
    Make sure all connections are properly inserted. Unplug/plug.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 12-01-2008 3:20 PM In reply to
    • jgn
    • Not Ranked
    • Joined on 04-17-2007
    • Dublin
    • Posts 6
    I had a similar issue on one of my speakers - turned out to be a cabling issue.
  • 12-08-2008 2:25 PM In reply to
    Hi again!
    I just noticed that the humming doesn´t start at once when the speaker are turned on but after 10-30 minutes. Is this a capacitor thing maybe?
  • 12-08-2008 2:36 PM In reply to
    Your problem sounds like the mains transformer laminations are vibrating at mains frequency, not uncommon.
    If this is the issue, then it can be resolved quite quickly depending on transformer type (i.e. screwed or bonded)
    Regards Keith....
  • 12-09-2008 7:41 AM In reply to
    Ok!
    I have penta II. Are there different kinds of transformers in the pentas? Is this a doityourself job or something for my workshop
    regards
  • 12-09-2008 7:48 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Is the humming audible from the bottom of the tower or actually played through the drivers ?
  • 12-09-2008 7:57 AM In reply to
    Hi!
    It's not from the drivers, sounds more like a resonance from the bottom. It's always at the same frequency but increases in soundlevel when the speaker have been turned on for a while.
  • 12-09-2008 8:13 AM In reply to
    • Dillen
    • Posts 5,008
    Is the cooling fins getting hotter than the other Penta after being powered up for 5-10 minutes ?
  • 12-09-2008 8:16 AM In reply to
    I haven´t thought about that. Have to check tonight. If this is the case, what's the problem? Solution?
  • 12-09-2008 8:48 AM In reply to
    • Dillen
    • Posts 5,008
    Reason: Too high idle current.
    Solution: Replace the idle current trimmer and readjust to factory specs. Worth doing the other tower while at it since it will just be a matter of time before it happens there too.
  • 12-09-2008 9:12 AM In reply to
    Ok!
    I guess this is for my workshop. Are these idle current trimmers standard components or do I have to get them first? Also, do you have a capacitor kit ready for the pentas?
  • 12-10-2008 3:33 PM In reply to
    Hi again!
    The cooling fins don´t seem to get any hotter on the humming one. In fact neither of them a
    is particulary hot. The hum is still there and if I had a guitar tuner it probably would be possible to check the freqency on the hum because it´s always the same. Very annoying when playing at low volume.
  • 12-10-2008 4:44 PM In reply to
    • Dillen
    • Posts 5,008
    A quite comprehensive (audiophile) kit is available but let's first see if it's needed.
    Have you tried switching the left/right channel cables to see if the problem follows the amplifier output or one particular speaker ?
    EDIT: Sorry, I must be getting old. You told that the humming was audible from the speaker physically. Of course swapping cables will not help diagnosing then. The humming speaker will have to be checked out. Could be as simply as transformer hum, as Keith suggests, in which case it won't be causing other faults, just plain annoying.
  • 12-11-2008 10:33 AM In reply to
    Ok!
    Thanks. Also both my displays have stopped working. They stopped gradually, at first they always worked when turned on but died after a while and now they are all black. Is this something for my workshop when he checks the hum. I tried to change display (with one I knew was working in another penta)but no response. Also tried swapping cables and outputs but...
    regards
  • 12-11-2008 12:19 PM In reply to
    • Dillen
    • Posts 5,008
    Yes, there's a capacitor or two in the displays too.
    Definitely a job for your workshop.
