1st March February 2012
Latest post 11-22-2008 4:25 PM by Beolab. 8 replies.
11-22-2008 8:44 AM
scottyltd
- Joined on 10-12-2008
- Posts 89
BeoSound 5 Display query!!
Hi all, I asked my local shop this question, and they couldn't answer it. It is a strange request but hopefully, someone here might be able to answer. Can the display be turned off whilst playing music? Reason for asking is that I would like the screen nice and black whilst playing music. For me, that would look so much smarter. Any feedback would be great!!
Christian
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 626
Re: BeoSound 5 Display query!!
I think the answer is no, it will only show album cover.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
The simple answer is NO from a B&O standpoint The long answer is whilst the Beosound 5 has a "Standby" button (top right hand side) that is the same as pressing the standby button on any B&O product or remote. The screen gets its +12 & +5 volts, video from the Beomaster 5 via a seperate cables to the Beosound 5 which is effectively a screen and input device to the Windows operating system, meaning that if you as a user had access to the operating system like you do on your Windows PC, then you could switch the screen off. Because the Beomaster 5 is running Windows XP Professional embedded, the B&O code only uses functions which it has written an API to interface too, and switching the screen off is not one of them from my investigation. From the service menu you can get to the windows desktop, but there is still limited funcctionality implemented.
PhilLondon
- London
- Posts 2,545
Was the BM1 windows XP embedded as well or was it a normal version of windows?
Alex
- Bath & Cardiff, UK
- Posts 2,990
No, there currently isn't. That doesn't mean there won't be when it's released however - we'll have to just wait and see!
Weekly top artists:
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
So the "P Mute" function will not work...
Christian
- Posts 626
Beolab: So the "P Mute" function will not work...
Beolab
- Sweden
- Posts 535
Christian: Beolab: So the "P Mute" function will not work...
Page 1 of 1 (9 items)
