For one, I am wildly guessing it can only connect to the local HD.
For 2, we had a snip of teh Beoconnect software posted. You have to drag and drop music from Itunes to the beoconnect software, that will transfer it.
For 3, the anwser I think is no.
If you are running a PC, I dont think it talks to Itunes. It will from a Mac. If you are using a PC, Beoplayer will be your library.
I checked both the Beomaster 5 and Beosound 5 manual but could find nothing about how to manage content.
Personally, I think best would be if it would behave like a BS6 and be updated through the Itunes Plug In.
I would think stability and content management are probably the areas where they are still fiddling with the software.
I would appreciate if somebody could upload the beoconnect manual for mac, that may explain a few more things.
Cheers
JK
