Latest post 11-15-2008 1:41 PM by jk1002. 1 replies.
Page 1 of 1 (2 items)
  • 11-14-2008 9:39 PM
    • Klas
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Singapore
    • Posts 96
    A few questions on functionality
    After reading various posts and not being privileged for a live demonstration yet;
    • Storage: Can it only access from hard-drive? Why not my files from my NAS? How do i copy; does the BM5 show up on the network as a remote hard drive (why only 100MBit and not gigabit?) I have ~700GB and growing FLAC lossless files
    • Playlists: So i have a Itunes playlist; where i add music constantly - will it always be in sync with Itunes or will i need to "add" music to the BM5 as i add to my computer?
    • Ratings - can you rate songs - as i have so much music i constantly update the rating's to ensure that my playlists get better and better - "More of the same" is not really that good if the track is really bad
    Grant me the serenity to accept the B&O I can't afford
  • 11-15-2008 1:41 PM In reply to
    Re: A few questions on functionality
    For one, I am wildly guessing it can only connect to the local HD.
    For 2, we had a snip of teh Beoconnect software posted. You have to drag and drop music from Itunes to the beoconnect software, that will transfer it.
    For 3, the anwser I think is no.
    If you are running a PC, I dont think it talks to Itunes. It will from a Mac. If you are using a PC, Beoplayer will be your library.
    I checked both the Beomaster 5 and Beosound 5 manual  but could find nothing about how to manage content.
    Personally, I think best would be if it would behave like a BS6 and be updated through the Itunes Plug In.
    I would think stability and content management are probably the areas where they are still fiddling with the software.
    I would appreciate if somebody could  upload the beoconnect manual for mac, that may explain a few more things.
    Cheers
    JK
