Hey gents,
It sounds like everyone had a good time at the event and most were impressed. Good to hear!
I wanted to clarify a few technical details as it sounds like you were given a less technical introduction to the product and I can tell that people have many technical questions to be answered.
1. Tired asked about his existing HD and how it would integrate were he to indulge in a BeoSound 5. Quite easily, actually. The BeoMaster 5 is loaded through one or more editing PCs, just like a BeoMedia 1. As with my BeoMedia 1, it not only feeds my link system, but acts as Network Attached Storage. What would happen in your case is that you'd set iTunes to locate your music file on the BeoMaster 5 and leave it over night. By morning the content will be on the BeoMaster 5 and you can safely re-purpose your hard drive. You will be able to access it just as you did before, since the BeoMaster 5 is a Net-Aware product.
2. It can be fitted with a wireless card just like the BeoMedia. This should make wiring and locating it a bit easier for some.
3. I believe photo & video were brought up. To clarify, it will handle both, but only on the TV side of it. These modules will be launched after the main audio concept, i.e. when it launches in the BeoVision 9 and BeoVision_. This will allow the BeoSound 5 to be located in a room without a TV and for the browsing to be completed on a TV where applicable.  This will be particularly good since the video output is significantly higher on the BeoMaster 5. Watching all of my torrent files on the BeoMedia was very enjoyable, but I would have loved better video quality.
4. As for the form factor, I'm pretty happy with the BeoMedia cabinet. It's funny that we compare it with devices like the AppleTV, which are quite petite. Earlier today I burnt my wrist on an AppleTV when I was adjusting a cable on the back of a cable box. Maybe if it was larger and contained a fan I wouldn't have been subject to such torment! It's not that I wouldn't welcome a smaller cabinet, I just look at the compromises in all my super small Apple products (my MBAir, AppleTV, etc.) and notice that they all have issues with overheating. I'd rather that issue be sorted out before B&O get into the one-upsmanship of cabinet reduction. Besides, if I don't have an extra .75 square foot to spare, I'm probably not buying B&O to begin with!
5. The three cables may seem awkward now, but this is what's going to allow the system to integrate into large custom jobs (our current focus) with ease. I can't tell you what a nightmare proprietary cables like the BeoCenter 2 cable are to run 100ft behind a wall. Having standard cables will allow a larger variety of placement and even accomodate multiple head units to a single master to make the BeoSound 5 an ideal full house solution. If there was a single umbilical, it would cause any number of headaches in our increasingly "custom" business.
6. It is pure mechanical sex.
7. As I mentioned with placement, I have installed plenty of BeoCenter 2s near seating groups instead of across the room. At its current size, you wouldn't lug it around anyway (it must weigh just over 10 pounds due to its base), so it may as well live on the coffee table. Now I'm not saying this will work for everyone, but it's an easy enough thing to do if you don't mind a little light construction!
8. It is specifically designed NOT to play a CD. The idea behind this product is to serve a defined customer profile, whereas the BeoSound 3200 and the BeoSound 4 were more migratory products. There is always a point at which you cast off the old media. If our systems still had cassette decks, we'd be laughed at. CDs are becoming tapes as we speak. If you still want to play them, we have 4 beautiful audio systems for you. It is likely that some customers of a certain age will not migrate to the digital media world. We'll continue to support them for years to come. Also, don't forget that you can integrate the BeoSound 5 into a setup with another BeoSound thanks to Option Programming. This would give you the best of both worlds.
Hopefully this clears some things up. I'm sure we'll all love being able to get our hands dirty when these arrive in shops.
best,
Trip
									    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
