Latest post 11-04-2008 4:38 AM by Dave0280. 5 replies.
Page 1 of 1 (6 items)
  • 10-27-2008 10:24 AM
    • Dave0280
    • Top 500 Contributor
    • Joined on 03-05-2008
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Avant VHS question
    Hi all - my 32" Avant (curved screen) VHS is not working - when I go to play a VHS all i get is a horizontal red line across the screen yet it will rewind the cassette via the buttons on the top of the TV. It will not respond to the remote at all but loads and ejects correctly. Any ideas.... Not a massive issue as don't use VHS often at all. Thanks in advance.
    Dave - Birmingham, UK
    Filed under: ,
  • 10-27-2008 11:49 AM In reply to
    Re: Avant VHS question
    Hi Dave,
    Try shutting off the power to the tv for a minute or so and then see if this doesnt help. This usually helps...
    If not; you have to get an authorised Bang & Olufsen service center to come and exchange the VCR.
    H
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 10-27-2008 3:21 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Dave. Failing that, make sure that both ends of the scart lead are shoved firmly home.  Over time, they sometimes work lose, especially on a TV that moves every time you switch on and off.
    Andy T.
    Poor me, never win owt!
  • 10-30-2008 5:54 AM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    I have a 32" VHS Avant that does not play the tape - a grey screen appears. The controls all work via the TV or the remote (eject, play, forward, stop etc etc) and it works fine on the input from a DVD or the TV via a SCART.  Does the last message imply that there is a scart connection for the internal VHS player that has come loose?
    Any thoughts on what I need to look at would be gratefuly recveived.....
  • 10-30-2008 7:39 AM In reply to
    There is a very short SCART cable from the VHS box at the bottom to the Vtape SCART socket above, so this is what Andy is describing..
    Regards Keith....
  • 11-04-2008 4:38 AM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Hi all - turning the power off to the TV for a minute or two sorted my problems out - VHS now functioning again. Thanks all.
