I have a 32" VHS Avant that does not play the tape - a grey screen appears. The controls all work via the TV or the remote (eject, play, forward, stop etc etc) and it works fine on the input from a DVD or the TV via a SCART. Does the last message imply that there is a scart connection for the internal VHS player that has come loose?
Any thoughts on what I need to look at would be gratefuly recveived.....
