I need 8002 circuitboard including the tin "can" mounted on it OR just the can assy OR the 40pin device inside.
Also useable would be a can and chip from an 8000 or 6006. Phil Hunt, Long Valley, NJ, USA 973 584 0161
Phil:
What happened? I thought you got it all working with the frankenstien 8000 CPU can?
Derek
For ages, finding a good tangential repairer in the states has been a huge problem. It seems this has finally been solved.
Keep up the good work, Phil !
