Latest post 08-18-2008 6:52 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 08-17-2008 12:24 PM
    8002: if I only had a brain!
    I need 8002 circuitboard including the tin "can" mounted on it OR just the can assy OR the 40pin device inside.
    Also useable would be a can and chip from an 8000 or 6006. Phil Hunt, Long Valley, NJ, USA 973 584 0161
  • 08-17-2008 3:35 PM In reply to
    Re: 8002: if I only had a brain!
    Phil:
    What happened? I thought you got it all working with the frankenstien 8000 CPU can?
    Derek
  • 08-17-2008 4:18 PM In reply to
    Yes it works, but I scavenged a repaireable 8000 to get it. And the 8000 processor deletes and modifies some of the 8002 functions. Practically not signigicant, but technically a knock-so I bought an 8002 as a parts unit, hoping to get the electronics,  and it had water damage which must explain the processor failure in that chassis. Remarkably, if I had another circuitboard assy, I could probably fix this one as well! So I'm motivated to find these parts. Phil
  • 08-18-2008 6:52 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    For ages, finding a good tangential repairer in the states has been a huge problem. It seems this has finally been solved.Laughing
    Keep up the good work, Phil !   Yes -  thumbs up
