David,
How good is your memory?
I am having a play with my BV4 & Beosystem 2 with a view to ML it from the lounge into our bedroom BV6 tele, so we can watch video, dvd, stb, lovely.
so rather than bash holes in the ceiling and plumb in some ML cable I had a bit of practice on the lounge floor with an MX4200 we have in the kids bedroom. So cross legged on the rug in front the BV4 the experiments started.
SO.. Unplugged the audio source ML plug for a bit and plugged in an ML cable between beosystem 2 and MX and joined the two with aerial cable from the 'link' socket on the BS2 and the MX. I set the MX to V.Option 6.
Went into the modulator menu, turned it on, picked a frequency and retuned the MX to match. I got a lovely pair of bars on my test pattern. I thought to myself I am winning here. thought too soon. when I came out of the test pattern and went to ordinary tele, snowstorm on the screen, doh.
I can't be far away, when I choose DVD on the MX, the DVD bursts into life so the message goes one way ok but get no signal in return. However when I switch back from dvd to TV the same picture appears on the MX screen as the BV4.... for a fleeting second and then it goes back to the snowstorm grrr.
I was told that the BS2 was just an avant without the case speakers and screen so if you solved your little dilema you might have the answers for me.
Unless there are some other clever clogs out there.
Pleased I didn't take the drill to the ceiling
