Hi all,
well I've two link rooms setup now (audio only).
I don't seem to find any details on using the BL1000's in link rooms.
Specificaly if I have the radio on in the main room and then switch it on in the link room and change the volume from there the volume also changes in the main room. I understood (wrongly?) that the volume control was independant. Also if switching off in the link the room the system switches off in the main room too. The PCG says both link rooms should be set to 2.6.
Any advice gratefully recieved.
cheers,
Kevin
