Add A. SETUP into your Beo4. Select it in the link room using list, press GO, adjust the volume to desired level then press list to scroll through Bass, Treble, Loudness, then S. STORE in the window. Press GO and it will store the volume to whatever volume it is currently set at.
Hope this helps,
Llewelyn
