Latest post 07-25-2008 3:08 PM by halid. 2 replies.
Page 1 of 1 (3 items)
  • 07-22-2008 3:21 AM
    Volume in the link room
    Hi, I have a pair of passive speakers in two link rooms. Right now the volume is pretty low when i switch them on. I have forgot how the to store the desired volume. Can anyone give me a hint ?
    Best regards
    Hans
  • 07-22-2008 12:50 PM In reply to
    Re: Volume in the link room
    Add A. SETUP into your Beo4. Select it in the link room using list, press GO, adjust the volume to desired level then press list to scroll through Bass, Treble, Loudness, then S. STORE in the window. Press GO and it will store the volume to whatever volume it is currently set at.
    Hope this helps,
    Llewelyn
  • 07-25-2008 3:08 PM In reply to
    Thanks very much, I will try this setup tomorrow !
    Best regards
    Hans
