Hello all... long time lurker, first time poster...
The past couple days I've spent cleaning up a new (to me) beomaster 4000 along with a set of beovox s45-2 speakers. mostly cosmetic work (i do a lot of woodworking... the rosewood veneer turned out to be *fantastic* on both these units), with a few minor solder, glue, etc. repairs on the side. overall, i'm very pleased with the results.
I was told the beomaster 4000 had the capacitors replaced, but i'm not sure when. that said, there are several lamps that are not working at the moment that i'd like to replace. Does anyone know if there is a capacitor / lamp kit for the beomaster 4000?  I would have thought something like this might be available, but I can't seem to find anything.
Also, my goals are to use this both for the FM radio (the reception on this is spectacular) along with digital (ala airport express / DAC) via the tape 1 input. Does anyone have / or know where I can buy the appropriate DIN to RCA plug for this unit?
Finally... i'd appreciate feedback on speakers than might be a better match for the beomaster 4000 than the beovox s45-2's. It's still too early for me to determine if this is a good fit or not, so consider the last question to be more along the line of "what do you use?" than anything else :)
Thanks in advance for all of your help,
--e
