Latest post 07-08-2008 11:41 PM by AlexP68. 6 replies.
Page 1 of 1 (7 items)
  • 07-08-2008 10:04 AM
    I bought my M70s new in '76.  In the late 80s the tweeters were blown.  A reputable shop replaced them with the closest thing available at the time since OEMs were not available.  They were also bi-wired and resealed.  Although a bit neglected cosmetically, they still sound good and get a lot of use in my #2 system.  From my reading here and elsewhere I understand that at 32 years old they probably need to be re-capped and refoamed.  For what ever reason, the foam isn't visibly cracked.  Do I really need to replace it?  So should I be concerned about the substitute tweeters when replacing the caps or just match the original caps?  Should I restore the original internal wiring or just externally jumper them for standard wiring as they are now wired?  Is there a list of the caps I'll need so I can order them ahead of time?
    http://picasaweb.google.com/teamo65/NewAlbum7808649AM
  • 07-08-2008 10:15 AM In reply to
    Re: M70s Recapping Questions
    Welcome to Beoworld!
    Some older B&O speakers suffer from foam rot. Some models had rubber sounds on the woofers in which case it is not an issue, and some of those that have foam surropunds seem to mysteriously escape it when other speakers of the same age suffer.
    If the speaker drivers all look and sound good then I would advise leaving well alone.
    The recapping refererred to is replacing the electrolytic capacitors in the speaker crossovers which can start to fail after 20-30 years or so. The main noticeable symptom is the speakers sounding  a little lifeless and dull. The requirements for this are a PM to Martin (Username Dillen on this  forum) to enquire about the availability of a capacitor kit,  a soldering iron and some solder. There are a couple of threads here that cover the process in more detail.
    Simon
    Edit: Just looked at the pictures and it looks like you have rubber surrounds so no re-foaming will be required.
  • 07-08-2008 10:17 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Welcome to Beoworld.
    Don't worry about foam rot - these have rubber surrounds so won't be a problem - ever! If you don't know the exact spec's of the thweeters then I would just replace the cap's as per original. I don't know of a list for the cap's but I would personally contact member Dillen (Martin) as he can supply you a full set for a very reasonable price.
    Chris.
  • 07-08-2008 12:02 PM In reply to
    Recently I have decided to replace the caps in the crossovers in my Beovox M-100. After some difficulties I have found the original ones from Wicon. (I think the crossovers in your speakers have Wicon capacitors too). My speakers are 30 years old. When me and my friend began the recapping we have measured the most critical old capacitor from the plate. Its meaning occured in the allowed limits of 10 percents and my friend said that no reason to do the recappingSmile. I think you should stay all as is still the speakers sound good in your taste.
  • 07-08-2008 12:43 PM In reply to
    Thanks.  I have sent said PM to Dillen.  I'm sure he'll respond shortly.  I'm looking forwarded to restoring these as they're the heart of my original system I bought in '76.  I got the M70s, a Beogram 1900 and a Yamaha CR-600 for $2300.  Quite alot considering in '74 vI bought a new Honda Civic for $3200 out the door.  The TT was the shortest lived due to the unavailability of replacement idlers.  If I knew then what I knew now I would have kept it.  Same for the rcvr which lasted 26 years until '92.  I guess that since I've always live 2-3 miles from the ocean the LA smog hasn't eaten the rubber.
  • 07-08-2008 12:46 PM In reply to
    AlexP68:
    Recently I have decided to replace the caps in the crossovers in my Beovox M-100. After some difficulties I have found the original ones from Wicon. (I think the crossovers in your speakers have Wicon capacitors too). My speakers are 30 years old. When me and my friend began the recapping we have measured the most critical old capacitor from the plate. Its meaning occured in the allowed limits of 10 percents and my friend said that no reason to do the recappingSmile. I think you should stay all as is still the speakers sound good in your waste.
    I have read at AK that even though the capacitence measures in limits that the ESR readings will be objectionable for 30 year old caps.  Did you measure ESR?
  • 07-08-2008 11:41 PM In reply to
    I didn't measure ESR. But probably I will do it if I get the special device. It's interesting for me too.
