Latest post 06-24-2008 3:10 PM by glug. 4 replies.
Page 1 of 1 (5 items)
  • 06-24-2008 6:35 AM
    • glug
    • Not Ranked
    • Joined on 06-19-2008
    • Posts 27
    Beo 5 remote, noise?
    Hi
    I've just purchased a new Beo 5 remote but am concerned that it is possibly faulty.
    When it is in the charger stand it emits a high pitched whistle, similar to a flashgun recharging.
    This sound stops after a few minutes then starts again.
    Do they all do this?
    glug
    Beovision 5 HD, Beo5, Avant x2, BL9, BL8000 x2, Beosound 1, BL2, Beosound 9000, Beocom2, Beogram 3000 , A8.
  • 06-24-2008 6:38 AM In reply to
    • M4SPM
    • Not Ranked
    • Joined on 04-16-2007
    • Burnley, Lancashire United Kingdom
    • Posts 38
    Re: Beo 5 remote, noise?
    Mine did the same
    It was faulty swapped it for another which is silent
  • 06-24-2008 6:44 AM In reply to
    Glug,
    You should NOT get any noise from your Beo5 when it is on the charger or anywhere else for that matter.
    I suggest you return it to your dealer for a replacement.
    Regards Keith....
  • 06-24-2008 6:45 AM In reply to
    • glug
    • Not Ranked
    • Posts 27
    Doh, that's a real 'Pain', back to the dealer then.
    glug
  • 06-24-2008 3:10 PM In reply to
    • glug
    • Not Ranked
    • Posts 27
    Fault was in the transformer/3 pin plug. Dealer swapped it for a good one straight awayYes -  thumbs up
    glug
