1st March February 2012
Latest post 06-24-2008 3:10 PM by glug. 4 replies.
06-24-2008 6:35 AM
glug
- Joined on 06-19-2008
- Posts 27
Hi I've just purchased a new Beo 5 remote but am concerned that it is possibly faulty. When it is in the charger stand it emits a high pitched whistle, similar to a flashgun recharging. This sound stops after a few minutes then starts again. Do they all do this? glug
Beovision 5 HD, Beo5, Avant x2, BL9, BL8000 x2, Beosound 1, BL2, Beosound 9000, Beocom2, Beogram 3000 , A8.
M4SPM
- Joined on 04-16-2007
- Burnley, Lancashire United Kingdom
- Posts 38
Mine did the same It was faulty swapped it for another which is silent
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Glug, You should NOT get any noise from your Beo5 when it is on the charger or anywhere else for that matter. I suggest you return it to your dealer for a replacement.
glug
- Posts 27
Doh, that's a real 'Pain', back to the dealer then. Thanks glug
glug
- Posts 27
Fault was in the transformer/3 pin plug. Dealer swapped it for a good one straight away glug
Page 1 of 1 (5 items)
