Hi.
I am thinking of buying a Logitech Z-5500 Surround system, can I tie the below mentioned B&O system in to it ..... And how do I do that (Special cables or what ??)
I will buy a LG 50" LCD flatscreen.
I have a Beosound 3200 (3-4 years old), a set of Beolab Penta (Orange Display 1992), One Beolab 2 Subwoofer (new), 1 Beoport (Old model), 1 Active link, 1 Passive Link.
I will at some point buy a set of Beolab 6000 or Beolab 8000 but would for this setup right now, use a normal set of speakers (without amplifiers).
I would like to hook up a non B&O LCD flatscreen, and a non B&O sourround reciever.
What do I, exept for one set of speakers, one sourround reciever and one LCD screen need to buy ???
I have all the cables needed to hook speakers and stereo up (master link cables) ... But what kínd of special cables do I need ?? Are those cables special made cables .... Or cab I buy on the net ???
And just to clarify :
I hoped to use my Pentas(with amplifiers) as rear speakers, and then a normal set of speakers (any brand, asume they would be with out build in amplifiers) as front speakers (Later on, I will buy a set of Beolab 6000 or 8000).
I would hope to use my Beolab 2 as Sub, and then need a normal brand speaker as center (assume this would also be without amplifier).
I live in Brunei, and can get more or less everything down here (No B&O though).... And I would think I will properly Buy LG 50 inch or so Flatscreen, and lets say a LG sourround reciever .....
What about cables ... Do I need to order some kind of special crossover cables from Europe ???
Thanks alot for your help
