Latest post 06-30-2008 7:45 AM by beobeo. 8 replies.
Page 1 of 1 (9 items)
  • 06-21-2008 10:20 AM
    • beobeo
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Spain
    • Posts 953
    Beomaster 3000-2 noisy channel
    Hello;
    After years buying only new B&O gear, I decided to explore the older product lines. As a starter , I put together a nice vintage set up comprised by a Beogram 4004, Beomaster 3000-2 an a pair of Beovox S-55.
    The lodspeakers soud really OK, the Beogram will benefit from a new band (a set from Martin is on its way) and a cartridge (probably follow the Sondsmith path) but it's the Beomaster the one that concerns me.
    After listening to the radio for two hours, I started to notice a strange noise on the left channel. Something like a false connection or dirty switch. It's very annoying. I thought initially it was a problem on the loadspeaker, I swap them out and the problem moved to the other one. I tried on the speaker 2 connection on the back but it is the same.
    Right now the problem starts as soon as I turn the Beomaster on. The noise remains for a minute or so after turning the BM3000-2 off.
    Any suggestion as to what could be the cause? Could it be a false contact on the circuit board? A dirty switch? Other thoughts?
    Thanks;
    Gustavo
  • 06-21-2008 12:37 PM In reply to
    • camshaft
    • Top 150 Contributor
    • Pennsylvania, USA
    • Posts 575
    Re: Beomaster 3000-2 noisy channel
    Gustavo this is actually a common problem on the 3000-2's.  The problem is often as you said a faulty contact inside the switch.  Disassembling the switches can be complicated, but others have had success by removing the front panel and spraying electrical contact cleaner in the backs of the switches while tilting the panel away so the fluid and residue runs out the front of the switches.  Then you should be able to clean up the residue and reassemble it.  Others may chime in with some better suggestions.
    Austin
    -Austin (resident audiophile skeptic)
  • 06-21-2008 1:17 PM In reply to
    • beobeo
    • Spain
    • Posts 953
    Thanks Austin;
    I imagine I only need to undo the screws at the bottom of the front and should be ready to try that out, or is there anything else to do to remove it?
    Gustavo
  • 06-21-2008 10:05 PM In reply to
    • camshaft
    • Pennsylvania, USA
    • Posts 575
    Sorry Gustavo, I can't remember, but the service manual is on the site.  If you search the forum you should be able to easily find some of the members who did it and ask them.
    Austin
  • 06-21-2008 10:08 PM In reply to
    • camshaft
    • Pennsylvania, USA
    • Posts 575
    http://forum.beoworld.org/forums/thread/94026.aspx
     http://forum.beoworld.org/forums/thread/116793.aspx
  • 06-23-2008 5:18 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Does the noise increase with the volume control ?
    Is the noise present on all FM presets ?
    PM me if this is the Beomaster, you bought from me.
  • 06-23-2008 5:53 PM In reply to
    • Teddy_fr
    • Not Ranked
    • near Angoulême, France
    • Posts 250
    This problem often comes from the "TEST" button at the rear of the Beomaster.
    Make it slide (up and down) several times after a good spraying of an electrical contact cleaner. Wink
     Marc
  • 06-30-2008 7:44 AM In reply to
    • beobeo
    • Spain
    • Posts 953
    Dillen:
    You've got a PM Martin.
    Regards;
    Gustavo
  • 06-30-2008 7:45 AM In reply to
    • beobeo
    • Spain
    • Posts 953
    I'm trying this tomorrow. I was away for a week and couldn't see your comments.
    Thanks;
    Gustavo
