When I turn on my Beocenter 2 to any source, the volume starts at the preset level of 45 and then immediately goes down to 00. I can try to manually raise the volume but it returns to 00. This started last night. I powered off the Beocenter 2 overnight and reset but to no avail. Thinking I had a bad Beo4, I used a different one after taking the original one to another room.
Any ideas?
Thanks,
Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002 BL11
