DVI-I = integrated. Means it carries analog and digital signal. The analog RBG are on the pins that surround the wide blade. So if your set doesn't have those openings, it's not gonna accept an analog signal and pulling those pins out of the adapter won't work.
You might want to try something like this USB DVI video 'card'
http://us.kensington.com/html/14499.html
