Latest post 06-07-2008 4:43 PM by Ryan. 1 replies.
Page 1 of 1 (2 items)
  • 06-07-2008 4:33 PM
    beovision 6 and dvi-d!!!
    Hi all
    My beovison 6 annoying has dvi-d for the pc input (rather than the dvi-i used on the other models).
    All of my laptops have vga outputs. Has any one ever seen a dvi-d/vga coupler. thus far i can onlt find dvi-i options.
    At a push could i use one of these and remove two of the pins and (somehow) reduce the width of the flat pin????
     Thanks in advance
  • 06-07-2008 4:43 PM In reply to
    • Ryan
    • Not Ranked
    • Joined on 04-16-2007
    • Toronto
    • Posts 29
    Re: beovision 6 and dvi-d!!!
    DVI-I = integrated. Means it carries analog and digital signal. The analog RBG are on the pins that surround the wide blade. So if your set doesn't have those openings, it's not gonna accept an analog signal and pulling those pins out of the adapter won't work.
    You might want to try something like this USB DVI video 'card'
    http://us.kensington.com/html/14499.html
