Hi everyone.
I am currently running Leopard and BM-Link 1.5 (firmware 1.30) on an iMac, everything works fine for me (though I have stuck to iTunes version 7.6 because i've read that there are issues if you go to 7.6.2), except that I can't control Front Row directly from my Beo4 because none of my IR eyes are connected directly to the BeoPort (I guess I can solve this by buying an extra one for my 'mac room' and configuring for just Link commands but I haven't got round to doing that).
However, I have two questions on which somebody may be able to help me:
1. I notice that Anders now has a new version of BM-Link available (1.5.2, firmware 1.31). Does anyone know what this actually does - I'd like to be fully up to date, but on the other hand my setup seems to work perfectly on 1.5 and there isn't any information in the change log that really gives much detail and if it ain't broke.....
2. Is there any way of examining the 'delivered' BM-Link source code / AppleScripts to see how they work? I am intrigued by how the Front Row support works in particular because Front Row isn't really AppleScript-enabled as far as I can see as a bit of an occasional scripter. I would like to code up my own scripts to do a bit more but I am a relative novice and it would be great to see more of how the current application works.
I apologise for these being rather basic questions.
Thanks for any help
/A
PS Anders if you are reading this then thanks for a brilliant application, I have gotten such a lot out of using it, I am just an old programmer who is keen to learn more about it.
/A
