1st March February 2012
Latest post 11-30-2010 11:57 AM by macjonny1. 30 replies.
05-24-2008 6:15 PM
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Beolink 7000 keeps switching on and off
Sounds like it is getting a signal from somewhere. Try taking it into a room with no B&O in it (if you have one  ) and see if it still does it.
Die_Bogener
- Joined on 04-16-2007
- Bogen, Germany
- Posts 1,010
Is there a dent right in the middle of the chrome plate? There is a piezo crystal sensor under this plate, you could disconnect the wire from it for testing. But do not solder on the sensor, solder only on the board... the piezo would go defect.
Beolab1
- Joined on 08-04-2007
- Hong Kong
- Posts 232
Hello Die Bogener! If it is the sensor, wouldn't it be switching on and off, even when in the charger? It now only switches on and off when taken out of the charger.
Die_Bogener
- Bogen, Germany
- Posts 1,010
Hmmm, then it cant be the sensor. There are 2 switches on the backside at the lower end of the BL7000. These switches are responsible for the motor control. What happens, if you put it on a desk, will it move? And if you put it on the desk with a small distance that these switches are not activated? Will it switch off? What voltage can you measure on the battery when it's operating? 6V?
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Now I'm having this issue with my Beolink 7000 when not placed on the charger.
By the way, this was the Beolink where I put in the batteries the wrong way
A friend of mine replaced a fuse that was blown, now everything works fine (RDS as well ) but the "switching on and off" issue remains...
Anybody?
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
I have had the same fault as posted in other threads...
I have replaced the touch plate w/ a brand new one, as well as the battery pack. My intent was to replace the blue cap next -haven't yet!
MoglesMac
- Joined on 04-25-2007
- Sweden
- Posts 109
@burantek, ahhh that was discouraging news for me, I was really hoping a new/semi-new touchplate would do the trick for my misbehaving Beolink 7000 (same problem, switching on and off outside the recharger). My last resort will have to be the infamous blue cap....
Regards
Jesper
Sweden
burantek
- SE USA
- Posts 6,214
MoglesMac:My last resort will have to be the infamous blue cap....
My fingers are crossed! You first!
MoglesMac
- Sweden
- Posts 109
Hehe thanx, seen your nice pictures in your other threads about BL7000, but I also think i might have additional problems with my two
missbehaving BL7000, also have some other smaller project in the "pipe" right now hehe but If i do anything I will report back even if i hit a brickwall :P.
Jesper
Sweden
burantek
- SE USA
- Posts 6,214
Member: Leslie and I have had a brief discussion re: the ON/OFF problem over here.
Sadly, the service manual supplies schematics for the base and not the remote -suggesting module replacement as the only solution. To followup on some comments made by Leslie that may offer more insight into the problem: The BL7000's that have the ON/OFF problem seem to work fine when in the charger. When removed, the ON/OFF appears. I am assuming at this point there must be something in the circuit between the battery and the board that is under/oversupplying voltage as compared to the base charger. Without the schematics, I am not sure what role the blue cap (PCB1-C13) plays in the circuit. Leslie had replaced the cap (had other issues as well) and it DID NOT resolve the ON/OFF problem.
Leslie
- Netherlands
- Posts 2,201
burantek:Leslie had replaced the cap (had other issues as well) and it DID NOT resolve the ON/OFF problem.
Jaff,
Sorry, some miscommunication. I have not replaced the blue cap because my Multimeter has a capacitor option which showed that the capacity was okay! However, maybe I should give it a try to replace it with a "brandnew" one. Who knows, will let you know!!!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Leslie:
You can't test them properly with a multimeter. The property that most often fails is not the capacitance, but ESR. You'll need a special instrument to measure that. Even if the capacitance value is still correct, the capacitor can be totally useless for its purpose if the ESR value has risen a lot from original, and that is what usually happens to aging electrolytic caps.
If this cap is a known troublemaker, don't waste too much time diagnosing it, just replace it
Leslie
- Netherlands
- Posts 2,201
tournedos:You can't test them properly with a multimeter. The property that most often fails is not the capacitance, but ESR. You'll need a special instrument to measure that. Even if the capacitance value is still correct, the capacitor can be totally useless for its purpose if the ESR value has risen a lot from original, and that is what usually happens to aging electrolytic caps.
That's (hopefully) good news Mika, thanks, maybe I'm lucky!
Now I have to look for a 680uF cap.
burantek
- SE USA
- Posts 6,214
My apologies for any confusion regarding the CAP/FUSE... but it looks like we are back up to speed!
Looking FWD to favorable results!
Leslie
- Netherlands
- Posts 2,201
Sorry guys, the cap 680uF replacement was no succes!
Have replaced all capacitors (11 pcs) but the on/off issue remains.
Gonna use that one for my LCS7000 wall charger
MoglesMac
- Sweden
- Posts 109
Awww ok, I will prob also use one of my defect BL7000 in a similar way, but always in a tablecharger hehe.
Thanx for testing it out for me and i will in a near future try to change the piezo since I have found a swedish provider to the right size :D.
Again, thanx
Jesper
MoglesMac
- Sweden
- Posts 109
@Leslie, sorry for bugging you again but saw now that you had a LCS7000 (very nice indeed) and I personally have a floorstand for my BL7000 and I think that you and I have same powersupply. I hope that maybe you have the wallplate to mount the powersupply on a wall. From the powersupply it seems too be a round thing with two "hook".
I hope maybe you have photo of it, if you have it that is, so i can try make my own :D
Cheers
Jesper
Leslie
- Netherlands
- Posts 2,201
Jesper, I wish I had one. Funny enough I never installed the LCS7000. It just sits in a box and still don't have any purpose for it. That's because of the Xtra speaker I got with the LCS7000. ALthough I got many advises how to connect this kit, I still haven't got the chance to install it.
burantek
- SE USA
- Posts 6,214
Leslie:
It is amazing that so many of these have this same common fault!
Well, I guess I'll be relegated to using it in the charger as well!
Need to find a LCS -that would be best!
