Latest post 05-22-2008 6:51 AM by Roger. 2 replies.
Page 1 of 1 (3 items)
  • 05-22-2008 2:52 AM
    Beovision 4 42" discontinued plasma
    Does anyone know which screen this is D9 or D10 we were misold an Hd ready screen a few years ago and are trying to sort it out.
    Has anyone else had problems with B&O customer services? and also is this screen 1080 lines or 780?
  • 05-22-2008 6:14 AM In reply to
    • BeoLad
    • Not Ranked
    • Joined on 07-23-2007
    • West Midlands
    • Posts 37
    Re: Beovision 4 42" discontinued plasma
    depends on ser number i can look into it for you if you get that ,
    where did you buy it from?
  • 05-22-2008 6:51 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    It is not the D9 or the D10.
    If you are based in Europe, the resolution changed from 852 x 480 pixels to 1024 x 768 pixels from serial number 18390228. Also, you need the BeoSystem 2 mkII to take advantage of the HD-Ready features of the display.
    If you have the US/CND display (type no 8956) then the resolution is 1024 x 768.
    All information based on the fact that this is the 42" panel.
    Roger
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
