Hello
I have a Beocenter 1 from 2005 (Typ no: 8523, SW:2.5, Acc: ML STB DSS) in one room connected to a Pace twin turner PVR , a VX7000 VHS and with a ML cable to the Beoport (SW: 4.65).
I have recently got B&O to connected these products with my Beosound 9000 (SW:2.21) (with a ML cable) and BeoLab 8000 which are located in another room. B&O managed to get it connected and I think I used to be able to listen to N.RADIO on the Beocenter 1 when listening to a CD on the Beosound 9000 in the other room. However, I realised that I did not manage to listen to the TV (analogue) on the Beosound 9000 and the Beosound 9000's radio on the TV, which B&O then tried to fix.
They managed to figure out why the analogue TV sound did not come through to my Beosound 9000 (too weak signal - so need to turn the sound to Mono) but not the link radio function (which is still not solved). When the last configuration was done, I “lost” the possibility to play N.RADIO on the TV when playing a CD on the Beosound 9000 and B&O claims that this was never possible in the first place. Nowadays, my Beosound 9000 lights up with N.RADIO when playing N.RADIO on my TV which I don’t remember it doing before. I am still convinced that I was able to play N.RADIO on the Beocenter 1 and listen to a CD on the Beosound 9000 at the same time, as described above, and wonder if anyone could put a final thought to my issue before giving up and admit that I must had been dreaming.
I think the TV is set to option 2 and the Beosound 9000 to option 2 wheras the Beoport is set to option 6.
On the link radio issue, I have decided to spit the antenna to the TV and connect it to the TV's radio to avoid using the link radio function which B&O never manage to set up.
Any thoughts?
