Hi guys...
On the...on the PCB 24 on the penta II....the P114 goes up to the jumper and on to P113-6 audio/video switch..
Which 2 legs is this jumper supposed to be between....???
THe displays are not working as of yet....
thanks !!!
Frank,
Do you mean J2 which is between P113 pin 5 and R26 ?
P114 does not go to a jumper, but it goes directly to P113 pin 6
Regards Keith....
ahh....just to the right of that on page 2-3...the P114 from R47 up to P113-6...
I beleive is the one in question...there are 3 legs down...and the tech tells me that there is a jumper between 2 of the legs...
thanks Keith !!
Below is the circuit you are looking at
