Latest post 04-23-2008 2:41 AM by Keith Saunders. 5 replies.
Page 1 of 1 (6 items)
  • 04-22-2008 3:16 PM
    PCB 24 on Penta II
    Hi guys...
     On the...on the PCB 24 on the penta II....the P114 goes up to the jumper and on to P113-6 audio/video switch..
    Which 2 legs is this jumper supposed to be between....???
    THe displays are not working as of yet....
    thanks !!!
  • 04-22-2008 3:31 PM In reply to
    Re: PCB 24 on Penta II
    Frank,
    Do you mean J2 which is between P113 pin 5 and R26 ?
    P114 does not go to a jumper, but it goes directly to P113 pin 6
    Regards Keith....
  • 04-22-2008 3:38 PM In reply to
    ahh....just to the right of that on page 2-3...the P114 from R47 up to P113-6...
    I beleive is the one in question...there are 3 legs down...and the tech tells me that there is a jumper between 2 of the legs...
     thanks Keith !!
  • 04-22-2008 3:55 PM In reply to
    Below is the circuit you are looking at
    Regards Keith....
  • 04-22-2008 4:09 PM In reply to
    Exactly Keith !!  so is there supposed to be a jumper there on the P114?? cause there is on these speakers..
  • 04-23-2008 2:41 AM In reply to
    The jumper is intended to be in place, its removed for test purposes only.
    Regards Keith....
