Hi there, with just 24 hrs till my father comes over for the "Yesteryear evening" that I have been planning for so long... I find that today its all gone a bit "limp" on me....
Here are the Symptoms:-
Place 33/45 on turntable
press play
Needle & other arm come across
Needle goes down before the begining of the Album
Then proceeds to gently limp across the vinyl untill the inner circle
Then lifts & Returns.
Checked that there are NO scratches on 'Old Frank' ( Sinatra that is)...
Now sweatin it!!
HELP !!!!!!
Life-is all about CHOICE....
