Latest post 04-17-2008 4:31 PM by woodmanta. 4 replies.
Page 1 of 1 (5 items)
  • 04-17-2008 3:20 PM
    Beomaster 3000 PROBLEMS HELP PLEASE!!!!!
    Hi there, with just 24 hrs till my father comes over for the "Yesteryear evening" that I  have been planning for so long... I find that today its all gone a bit "limp" on me....
    Here are the Symptoms:-
    Place 33/45 on turntable
    press play
    Needle & other arm come across
    Needle goes down before the begining of the Album
    Then proceeds to gently limp across the vinyl untill the inner circle
    Then lifts & Returns.
    Checked that there are NO scratches on 'Old Frank' ( Sinatra that is)...
    Now sweatin it!!
    HELP !!!!!!
    Life-is all about CHOICE....
  • 04-17-2008 3:51 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beomaster 3000 PROBLEMS HELP PLEASE!!!!!
    Could you please verify exactly what equipment you have? Is it a Beomaster 3000 tuner/amp with a sperate turntable? If so I need to know the model of turntable - it will be printed on the front somewhere and will be a Beogram XXXX.
    Chris.
  • 04-17-2008 4:00 PM In reply to
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    My Beogram 5005 did exactly this on my Beosystem 5000.
    It seems to be that if the Beocord was plugged into the master, but not into the mains, then the gram would drag itself over the LP, then return to rest.
    Luckilly this was before I bought a cartridge without knackered suspension.
    So its worth checking all other datalinked equipment has a mains supply!
  • 04-17-2008 4:07 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Are you not talking about a Beocenter 3000?
    Edit: Oops there is no Beocenter 3000!!
    Durban South Africa
  • 04-17-2008 4:31 PM In reply to
    Hi there, its as follows:
    3361048
     oooops sorrry thats the serial number.. its a beogram 3000
     It is plugged into the mains off its own power cord + linked to my Beomaster 3000.
    Does this help?
