Can a U.S. Beogram 7000 (120V) be modified to be a European Beogram 7000 (220V)? I have read on the forum that some equipment has voltage switches inside that can be switched to the correct voltage. Is that the case with a Beogram 7000? If not: is there another solution? Thanks in advance for your suggestions!!!
