Hi
I have a BV7 in the bedroom, and a BeoLink passive in the en-suite. These are both set to option 5, and so respond to their own commands. If I want to listen to CD through the BV7 I press AV CD on the Beo 4.
I want to use the Beo5 in the bedroom because it's so much easier than sky, but can't get it to operate the devices in option 5 correctly.
I have a zone called bedroom containg just the TV which is in option 5, and another zone, bedroom 1, for the BLpassive also in option 5. It doesn't work, and I can't set the buttons manually as I can't find the AV option in the IR list.
Any ideas?
