Latest post 04-13-2008 5:40 AM by PhilLondon. 7 replies.
Page 1 of 1 (8 items)
  • 04-12-2008 9:57 AM
    Option 5
    Hi
    I have a BV7 in the bedroom, and a BeoLink passive in the en-suite.  These are both set to option 5, and so respond to their own commands.  If I want to listen to CD through the BV7 I press AV CD on the Beo 4.
    I want to use the Beo5 in the bedroom because it's so much easier than sky, but can't get it to operate the devices in option 5 correctly.
    I have a zone called bedroom containg just the TV which is in option 5, and another zone, bedroom 1, for the BLpassive also in option 5.  It doesn't work, and I can't set the buttons manually as I can't find the AV option in the IR list.
    Any ideas?
  • 04-12-2008 12:12 PM In reply to
    Re: Option 5
    There is a tab in Beo5 config prgm thats called Link. And you must set this to 1
    Your dealer will do this for you
  • 04-12-2008 12:46 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Option 5
    If you want AV-CD on Beo 5, create a button that sends CD in video mode: 0:000:TV:CD. The same if you want AV-TV: 0:000:RADIO:TV.
    Hope this helps
    Stefan
  • 04-12-2008 1:28 PM In reply to
    Re: Option 5
    Why don't you change both to option 6?
  • 04-12-2008 2:26 PM In reply to
    • stefan
    • Posts 1,733
    Re: Option 5
    Audio and video in option 6 in the same room won`t work, because both systems react to both commands. So, if you press "1" you will get "11"....if you press "up" you will get up twice...
    Stefan
  • 04-12-2008 4:26 PM In reply to
    Re: Option 5
    I had not realised they were in the same room...
     p.
  • 04-12-2008 6:23 PM In reply to
    Re: Option 5
    stefan:
    Hope this helps
    Stefan
    Many thanks, that's exactly the info I was after
    re the other response about the link function.  Link has no effect when a product is in opt 5, only in opt 4
  • 04-13-2008 5:40 AM In reply to
    Re: Option 5
    Link has an effect in Option 5 or 6...
    Link allow you to choose a source of the main room when there is the same source in the link room.
    If you have a DVD in the link room and in the main room, pressing DVD would activate the local DVD player, Link-DVD would activate the DVD player in the main room.
    Link+TV or Link+DTV would use the Tuner of the Main Room as well.
    p.
