Latest post 04-04-2008 9:07 AM by thavn. 2 replies.
Page 1 of 1 (3 items)
  • 04-04-2008 2:06 AM
    BV5 now to the bedroom
    Hi, my 2005 Beovision 5 sadly is now off to our bedroom. I shall keep the lab 5s, 3s and BS9000 in the family room. I am planning to convert our family room into a home cinema. It is 30' x 18'. I am looking for the forum's advice on compatible high end Projector, Beo System 3 and a high end motorised screen dropping down from the ceiling.
    I would like to continue with the same level of integration I have now. i.e. all contolled from either my Beo4 remote or a new Beo 5.
    I have a budget of about $ 30,000 AUD. This would get me a BS3 for around $ AUD 8000, a Stewart Firehawk or similar screen for about AUD 10,000 and a projector for around $ 12,000.
     Does anyone have any views about which projector ?> I currently have a B&O compatible DVD Player (Panasonic A30) controlled via a B&O DVD Controller.
    It is also a pity to lose the BV5 surround system control now un-connected to the bedroom.
     Peter
  • 04-04-2008 8:06 AM In reply to
    Re: BV5 now to the bedroom
    I think the installation can be quite expensive unless you do it yourself. Personally I would keep the BV5 for now and use that as a base to built a home cinema.
    Unless you can keep out daylight the projector is not of much use. This is in the end why I bought my TV.
    So I would look for Screen & Projector, professional installed and probably a Blueray player since you are after the high end.
    Cheers
    JK
  • 04-04-2008 9:07 AM In reply to
    I'm not sure I feel sorry for you! A BV5 in the bedroom sounds nice.
    However, why don't you keep the BV5 in the living room, and add a projector for movies etc. You can have a curtain coming automatically down from the roof in front of the BV5, and use the same surround setup.
    The best of two worlds.
    BV10, Avant DVD, BL5, BL4000, BS2300, BV6-26, MX 4002, 2xBeocom 6000, LC2
