Hi
Just wanted to share my experiences with a newly purchased earset 2. I exchanged it from a prevously used sony ericsson hbh-300 with that long pin-style reaching almost to the mouth (too big looking)
Sound compared with the hbh-300, both used with the same serene phone: Very rough, flat and sticky/high treble. Some calls hurts the ear even at lowest volume. The hbh-300 was much more soft in the sound appearance.
 Quality: The bluetooth connection get clips and pops with my serene in my belt pocket 40cm away. When I take the Serene out it all get non-interference and clear. When I have the Serene folded and in my closed hand I very often also get interference in the connection. The hbh-300 was never this picky with the distance and it was purchased 4 years ago. Also often I get disconnected in the same situation: I make a call. All good. I hang up, dial another number and TADA, the phone makes the  call without the headset and I get the answering voice from the one I call heard from the Serene and the headset icon on my Serene is suddenly gone. :(
 Comfort: after like 5 minutes the earset-2 hurts the my ear. I found out that I could just hold the speaker to the most upper part of my ear (above the ear tunnel) and then fold down the earhook to fix it at that position. But that way I will have to have more volume to hear the caller and also other people will hear the sound since the headset is virtually above the point where it should put in the speaker into.
Look: Yes it is very different and has that classy and quality appearance. But why is the speaker bulb angled???? It just makes the whole headset rotated and the lower part sticks out from Your ear and I think that makes it look more clumsy, or am I way out of line here?
